Bredebahn
Cinema, Garden Railway, Private Flying (licenced p
By now I had got wise to tracklaying skills in LGB. Rather than the anchored flexitrack of the smaller scales I had started to revert to set-track days and to plan the track layout accordingly. I found that it was relatively easy to create a good looking and stable trackbed by purchasing 25kg sacks of fine rockery aggregate (preferably less than 6mm nominal) and pouring this into a dug trench to a depth of a couple of inches or less - the trough being lined with the plastic bag that the aggregate arrived in having been cut into strips (yes, this causes a problem with the order of things on the first bag, but after that you'll be fine...). Level off the surface of what has become the trackbed and tamp down (walk on it). Lay the track on top and fettle in, checking levels. Then pour aggregate (which I'll now call ballast) over the top and sweep clear leaving the rails exposed. Water lightly with a can and with a bit of luck you're done. You will have to lift and tamp and fettle every few months as the track will move, but this is prototypical and all part of the game anyway. There'll be a lot more on tracklaying as we proceed. Oh, and I found that 25kg bags, whilst convenient, will result in an unbelievable amount of bags being required. Try 1 ton crane bags when you've got going...........
Anyway, here's some early trains.......
