Neil Holiday
is it possible to have a bimodal loco conversion, so that it can run independently on track and battery power?
Jon (Zerogee) has done a coupleis it possible to have a bimodal loco conversion, so that it can run independently on track and battery power?
What is the reasoning behind doing that?
If you have insulated the wheels and remove any pickups then you should be able to just run on battery regardless of what potential is across the rails.
I am at a loss as to why this is done is there a logical explanation that I am missing?
With my testing rigs I wanted to be able to check out the Sounds on Track and then switch to Battery Only to compare Functions. It convinced me that I will leave the option of Track Pickups for pretty well the same reason that Jon has. But it also allows access to reprogramming of the Chip if required, though this can be done via the Aristo DCC Battery Kit it cannot be with the Fosworks Battery kit. Though being used to Massoth reprogramming (well some of it anyway) it made sense to leave this option rather than faffing to learn a new system. Not enough Ram in me bonce you see!What is the reasoning behind doing that?
I think it's easier to have two locosWell, in my case the reasoning was simple - I wanted to have a battery loco that I could take to run when visiting lines that had dead rails, but also to retain the ability to run it on track powered DCC (or DC for that matter) at home, or visiting lines that had track power. While I removed the skates from both converted locos, I left all the wheel pickups in place, they are simply connected through the DPDT track/battery selector switch.
Sometimes I simply want to be able to drive the locos on my regular Massoth DCC control system rather than having to use a separate radio handset.
But certainly more expensive, without going down the Battery/Track powered discussion again I think it logical to provide for both if that is ones wish.I think it's easier to have two locos![]()
Yes, slightly facetious, but I'm not into the argument - I do both, track and battery - to suit my moodI realise that was (mostly?) a joke, hence the emojis..... but being serious, it was a case of the difference being one DPDT switch that cost about 60p.... so why NOT have the option of either power source?
As JonD said, the track/battery debate is getting about as contentious and polarising as politics and religion, so let's keep off it if we can.
I don't know, maybe using both on one loco labels me a "heretic" to the True Believers on BOTH sides of the argument......?
How you get there - well, there's 101 ways of killing a cat![]()
I think I still had in mind one of the earlier comments about availability of space in a loco for all of the R/C gizzmos - some (locos) have got it, some ain't. But then again, there are trailer (wagon) options so, as you say it depends on personal preference, circumstances and needs...Absolutely! There is room in the hobby for all methods of propelling your locos (and indeed several combinations of such, as we've been discussing here), depending on personal preference, circumstances and needs.... and long may it stay like that!
