Beginner in R/C in Bachmann Locos
Emilys dad
2 Jun 2015
35
2
People's Republic of Liverpool
Hi all,
After a bit of research, I've come up with my plan to R/C my 3 strong loco fleet, consisting of an Annie, a Connie and a Baldwin 2-4-2. They run 4 Bachmann coaches or 4 or 5 wagon trains around a mostly flat with 1 incline contiunous run.
I'm planning on a Deltang Tx22, controlling an Rx65-22 in each loco, with the tender locos being fitted with 2 7.2V C NiCds, and the 2-4-2 being fitted with either C or AAs, deending on space available.
Well, that's what my research show to be the (possibly) best plan, does anyone have any comments at all?
I'll probably build the Tx myself, quite happy to be handy with a soldering iron and heat shrink...
Cheers
E.D.
3,521
Hello ED,
I assume you actually mean NiMH batteries, rather than NiCad's?
And that the two 7.2V packs will be in parallel?
A Rx65c is limited to a supply of 3-13V (3-8 NiMH cells). - I would recommend eight-cells (9.6V) for these loco's.
If you want to go to higher voltages, then there are other receiver options (with a separate ESC) you may wish to consider?
GAP
14 Jun 2011
4,059
944
Australia
GAP
14 Jun 2011
4,059
944
Australia
While 9.6 volts might give an actual prototypical scale speed, I think you probably want more like 14 volts on tap.
"Emily's Dad".... it might be too slow for Emily
Which is why I went for 14.8V Lithium for my Connie and Shay, they are big heavy locos, I mostly use 12V but used 10.8V NiMHs for my smaller locos (LGB Stainz LGB tank engine etc).
4,993
Not quite sure that I understand the full issues of Deltang Voltage Maximum but Phill’s cautions and advice are to be listened to. Should you want more volts and or amps then Fosworks or Crest Revolution Train Engineer may be alternatives to think about. Both Deltang and the Crest can have more than one locomotive at a time running should that be something that you need. With Fosworks you would need to bind a locomotive each time you use it should you only have one transmitter, much easier with the new binding procedure.
3,521
You CAN use greater voltages with Deltang equipment, but just NOT with the Rx65c 'as is'..
There are 'enhanced' versions of the Rx65c, and Rx66a, which are good for higher supply voltages, or there are options which use a separate ESC.
All are compatible with the Deltang Selecta system.
Emilys dad
2 Jun 2015
35
2
Hello ED,
Yes the packs would be in parallel to give 14.4V.
Based on that I'll change the receiver to an Rx66-22 as I understand.
Cheers
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
parallel is same voltage 7.2, double the amp hours... both positives together, both negatives together, the voltage between the positives and negatives remains 7.2 volts
to get 14.4 you put the packs in series, the only connection between the packs is one pack's postive to the negative of the other pack. The unconnected terminals are 14.4 volts
probably just a terminology mistake
