Hi everyone. I've been busy modifying my tram with a lot of help from here. I've changed the pole to pantograph as per Gizzy's thread; http://www.gscalecentral.net/tm?m=67432&high=tram+pantograph < Link To http://www.gscalecentral....p;high=tram+pantograph
As I'm running an out and back line for the tram the pole just didn't look right running 'backwards', so when a pantograph appeared on ebay I couldn't resist but give it a go.
Then my attention turned to the rather poor excuse for a power block. Yet again a thread came to my help with Dutchelm's conversion to a USA Trains NW2 motor block; http://www.gscalecentral.net/tm?m=25354&high=nw2+block. < Link To http://www.gscalecentral....54&high=nw2+block. G-bits (Resin d'etre) was able to supply the block (along with new wheelsets for my GP7), great service from Jonathan.
Instead of attaching the motor block straight to the tram floor, I cut a hole for the block to sit up into the floor itself, then made a strip of plastic which I screwed the block to. This was done as I felt the wheels were a little too low, making the tram sit quite high above the rails. Cutting the block into the floor allowed the tram to sit about 4-5mm lower, which makes a big difference .
Now I would really like a little help with finishing it off. I want to get rid of those horrible 'bumpers',
but don't want a gaping hole at each end. Has anyone else done this and found or made a suitable 'filler'? I know most trams had a catcher to avoid objects from going under the front, I feel that the lolly sticks could come in handy here.
I think sorting out the ends will really finish the tram off. The NW2 blocks are really smooth and quiet and the pantograph makes it look great in any direction now.
Pics and how too's would be great if anyone can
Many thanks,
Tim
Many thanks,
Tim
