Paradise
Following a recent question on a related thread I thought I would start a specific thread on the subject of the replacement of split plastic gears on the 4-4-0, 2-6-0 and 2-8-0 Spectrum models.
A few key points:
1) The replacement plastic gears on axle from Bachmann spare parts for the 4-4-0 / 2-6-0 now have a D shaped hole rather than a spline. I bought two replacements from Bachmann spare parts, one came already split at the hub when I received the order but this may have just been an isolated incident. It is still firm on the axle.
2) The replacement delrin gears from 'North West Short Line' as listed on their old site was somewhat confusing. The 24 tooth gear is listed as a replacement for the 4-4-0 but the two 4-4-0's and 2-6-0 I have repaired both had 25 tooth gears. Several years back on a related forum, I recall Kevin Strong stating that he had replaced several gears in the Spectrum 4-4-0 / 2-6-0 and they were all 25 tooth.
3) Several web pages/pdf online with detailed instructions on doing the repair state ordering the 24 tooth gear replacement from NWSL although the pictures in the instructions show their old cracked gear which is 25 tooth.
4) The replacement 25 tooth brass gear from Bachmann for the 2-8-0 has been used by some people to repair the 4-4-0 and 2-6-0 although some modification may be needed to press it on the axle which is splined for interference fit where the gear sits. It is also slightly thicker at the gear face than the plastic gears which may not be an issue. All the Bachmann plastic gears have a face of approximately 3.9mm. The brass and NWSL delrin ones are 4.4mm.
Perhaps there are some Bachmann 4-4-0's with a 24 tooth gear but I have never come across any reliable source of that. I suspect there may be confusion from the NWSL 24 tooth gear product description. The question mark speaks volumes. Best to check the tooth count on your cracked gear first before ordering from NWSL.
NorthWest Short Line
From left to right below:
Original Bachmann 2-6-0 25 tooth gear on 46mm splined axle. (split)
Replacement Bachmann 4-4-0 25 tooth gear with D shaped hole (no spline) on 43.4mm axle. (currently Bachmann spare parts list this as replacement for both 4-4-0 and 2-6-0).
Original outside frame 2-8-0 25 tooth gear on splined axle (split)
Replacement Bachmann outside frame 2-8-0 brass 25 tooth gear on axle. Gear face 4.4mm.
NWSL 24 tooth delrin gear. Part No. 2223-6.
NWSL 25 tooth delrin gear. Part No. 2226-6.
I hope this helps others avoid some confusion when fixing their cracked Spectrum gears.
Some related links. Just be careful what you read.
Bachmann Forum
Bachmann Mogul - dreaded split gear issue - G Scale Central
Issues with Bachmann Consolidation gears? - myLargescale.com > Community > Forums
Axle with brass gear (Large Scale 2-8-0) [G813X-AXELBG] - $11.00 : Bachmann Trains Online Store!
A few key points:
Bachmann Forum
