I am in the process of converting my fleet of Bachmann Fn3 scale locos from track to battery powered, 6 down 5 to go. I am using 14 cell AA NiMH battery packs. I have noticed that once thought defunct smoke generators (a noted Bachmann Achilles heel) have now suddenly come to life and are producing decent levels of smoke. Happy days ! My locos include both those with the Bachmann PnP PCB and those that predate that standardized fitment.
Now the question - I have been warned that the voltage output of my standard spec' battery packs, 16.8 v fully charged, will in all likelihood burn out the generators' heating element in short order. As a result I was told I should only operate a generator once the loco has been run for a while to allow the voltage output from the batteries to subside to a more suitable levels. Old wives tale or true ? What is the ideal voltage range that these unit should operate in and are they protected by some sort of voltage regulator in a loco's circuitry ? Note - the battery conversions, as made, are delivering full battery voltage, not the ESC's variable, to such loco ancillaries as lighting and smoke generators, so they are "on" all the time the loco is switched on, or if the accessory is itself switched on separately.
Looking though all the schematics supplied with these locos there is no reference to the ideal voltage range or a description that shows a identifiable voltage regulator directly attached to the generator (as the early Climax models were fitted with). My experience tells me that somewhere on these locos circuitry there will be a voltage regulator, or multiples, to protect various devices from an over voltage. Likewise, no information pops up with an appropriate Google search. I have run my Heisler with the smoke unit switched on after an hour of running from being fully recharged. It was impressive, how I always felt a smoke generator should operate. Your thoughts please. Max
