Flying15
In a few threads there’s been quite a few suggestions on how to build Gordon (Thomas and Friends)
Well this isn’t quite about building the big blue useful engine, but a very similar looking engine ‘Green Goddess’ of the Romney Hythe’
Effectively a miniature Gresley A1 (later A3)
The build methods for the superstructure and tender were similar to the RHDR 4-8-2 I built a little while ago
The loco chassis was a major departure for me in that the loco isn’t Bachmann based But uses the motor block from an Aristocraft pacific
This came secondhand without valve gear, so a solution was found by cannibalising one of my Annie’s (that now runs in the more simple connecting rod only form)
The Aristo chassis was extended using some steel box section I had to which the cylinder block was added
The connecting rods big end was drilled out to allow the rod to fit the Aristocraft pins
A Bachmann bogie from the old time 4-4-0 was filtered and a simple trailing truck built
This sits/swings within the frames which on the real engines had Cartazzi axle boxes as per Gresleys LNER (and the RHDR Greeley)Pacifics .The materials for the build comprised:-
Aristocraft Pacific motor block
Bachmann Indy 2-6-0 tender chassis
Bachman Annie Cylinders and valve gear
Bogie from Bachmann 4-4-0
Plasticard/styrene sheet and sections
80mm perspex tube
75 mm rain water down pipe
Wire for handrails and plumbing
Chimney,Dome + Axlebox castings from Walsall models
handrail knobs from GRS
Buffers from Williams Models
Pop rivets for safety valves
I have on order name and works plates from Peter Woods
I’ve named a few suppliers here as I think it’s good to spread the word on suppliers as without them this aspect of our hobby becomes more difficult
I have no connection with any of them beyond being a customer
Whilst the loco is based on the RHDR Pacifics it isn’t dead scale and there are quite a few departures to ease/speed the building process
Below are a few illustrations of the build hopefully in the right order
The Aristocraft Pacific is there to show how the motor block should be used
80mm perspex tube
