Aristo-craft 5480 Basic Train-Engineer
Henri
refuses to grow up
6 May 2016
2,060
1,232
56
Hoeksche Waard - Netherlands
After playing with my trains for the first time ever last Sunday, I'm thinking the 'trottle' from LGB I wanted to use, is quite something for the back...
What are the options to have a hand held speed control? I stumbled upon the Aristo-craft 5480 Basic Train-Engineer which for € 40,- average seems a good deal to me?
I know it maxes at 2 Amps, but that will be sufficient for me to start with.
Other options? (DC power, see forum...)
Zerogee
Clencher's Bogleman
1,723
North Essex
There are lots of folks who have got on very well with the Train Engineer for years, Henri, but just one word of caution - I THINK that the basic version (the orange one?) only has a PWM (Pulse Width Modulation) power output, while the more sophisticated black one has switchable PWM or pure linear DC output.
Now, this won't probably matter too much to you at the moment, BUT if you ever get a loco with a DCC decoder fitted, these do not like being fed with PWM DC.
Just something to think about, it depends how much you want to look to the future as opposed to just getting up and running with something low-cost now.....
For what it's worth, if I were in your position and just wanted to have simple DC with one small loco running at any one time, I would probably look for a second-hand LGB50080 or similar - one of the little all-in-one transformer/controllers with a 1-amp output - which will be plenty for the locos you have now - and you should be able to find a good used one for around the £20-£25 mark.
3,522
For a single engine, on a small line, not a problem..
for a little more initial outlay, you could use a small R/C handset, and an 'ESC' (Electronic Speed Control)/Receiver to achieve the same thing..
If you decided to go battery-power in the future, you would then have the components for one loco already.. Correct choice of controller, and you wold only need additional RX/ESC for the other loco(s). - Plus batteries, of course.
http://rctrains.co.uk/
ntpntpntp
275
UK
United-Kingdom
Ah... that's the orange Train Engineer I think? As I recall, folk recommend NOT using this one with DCC decoder fitted locos (and possibly not with locos with a lot of electronics) as it ONLY outputs PWM pulsed power which can confuse decoders. The more capable (and more expensive) black Train Engineer can be switched to smooth linear DC.
[edit] Jon Zerogee and I must have been writing our posts at the same time again! [/edit]
JRinTawa
Member of the Wellington Garden Railway Group
1,086
Tawa
Range on the Basic Train Engineer i.e. the orange version is limited and as others have said the PWM can cause some issues. I started with the orange one but soon changed to the large capacity black Train Engineer. If you keep a watch these too come up second hand from time to time. The Train Engineer can have it's output/track feed to PWM or linear DC, I run mine on linear DC. Hmm well more like "ran mine" as I've now graduated further to battery power then live steam - but that's a whole 'nother story!
Zerogee
Clencher's Bogleman
1,723
North Essex
But the LGB 50080 is something I already have more or less. The 'problem' is that it is located at ground level. No comfy control...
A wireless remote control would be wonderful!
Ahh, right.... a good point!
You could always mount the powerpack/controller on a post so that it is about waist height..... but you still wouldn't be able to wander around or sit in a comfy garden chair with a beer in one hand and the controller in the other.....
Gizzy
36,149
2,278
63
Cambridgeshire
If you do go for the TE Henri, go for the black one as others have said.
I had one myself for several years for the very reasons you mentioned.
I eventually upgraded to MTS (DCC) but I was more than happy with the TE....
3,522
Thanks!
RC Trains looks like something useful as well... Full power to the tracks and an ESC in each engine... Interesting...
You can put an ESC between a controller and the track to start with.. Gives you RC of an analogue layout (one train)..
a98087
8 Nov 2009
1,846
199
36
Wiltshire
Gavin Sowry
2,490
70
Hutt Valley, NZ
;) Forever the gentleman, JR has retained TE for guests who turn up with 'out of the box' equipment.
merlin
Model (all scales) & 12":1'
17 Jan 2013
176
57
Somerset (occasionally in Spain)
I use a 'Black' TE. and I swear by it. I was fortunate enough to see it lurking on a trade stand, S/H, at a model railway show a few years ago and bought it for the princely sum of £60. I have since added a fan, also obtained S/H, at Stafford members sales last year. I use a 10 amp power supply which came from the come-in-handy store (isn't it nice when you can justify hoarding! :D ) and i've connected the arial via a plug and socket to an old telescopic car arial (another come-in handy!) which sits in a hardwood block attached to the side of the track bed. Disconnect the multi - pin connectors and the arial lead, remove the Rx from its mounting and put it away at the end of the day. Put the water-proof cover over the control panel and power supply, and switch off at the exterior socket under the track. Job done!
Henri
refuses to grow up
6 May 2016
2,060
1,232
56
Yes I have managed to buy a 2nd Hand 'black' TE with three switch decoders in the mean time. I mentioned the 'orange' set on a Dutch G scale forum and someone offered me the black one for a very reasonable price, including the switch decoders (which actually have never been used)
JRinTawa
1,086
Tawa
Excellent result Henri :clap:
Dan
28 Jan 2010
660
52
Eastern MA, USA
You can use PWM on LGB DCC engines by installing a Non-polarized capacitor across the output of the controller (input to the engine electronics) . The capacitor will filter out the pulses and the engine will just see DC power!! Since the pulses are at a high frequency, just 2.2 microfarads will work.
PS this is what Aristocraft does with their 10 amp 27mhz train engineer.
St A & M Rly
29 Aug 2017
18
3
69
St Andrews Scotland
Dam
Thefitting of a 2.2 microfarad capacitor on the output to get smooth DC sounds a little simple! Are their any other changes to the circuit when you switch the Train Engineer fromPWM to analogue in the base station.
If it is then it will save many from the expensive modz when the transmitter finally fails.
Amacf
St A&M Rly
Tony Walsham
50
Casino, NSW
Dan,
You can use a simple non polarised capacitor on board but be advised filtering above .1mfd across the output FET's could make them overheat.
You need something like the # 57091 PWM - Linear filter board Aristo used to make.
I have noticed that regular DC locos become a little more ON - OFF moving off from stationary. They lose the smoothness of PWM.
