Jon,
[quote author=dunnyrail link=topic=299347.msg338279#msg338279 date=1420188382]
Presumably the Blue Box is some kind of Battery?
[/quote]
Yes I used what I had, LiPos intended for model aircraft, boats use etc. They are easy to find and cost effective (Hobbyking), but don`t come with any protection circuitry to prevent over charging or over discharging both of which are fatal for LiPos.
These need to be removed for recharging. To prevent overcharging I use a professional LiPo charger. To prevent over discharge I use the voltage monitors available for model aircraft that attach to the balance leads, they make a loud noise when the voltage drops to a defined level, at which time it is time to stop and swap the battery.
These batteries can source far more current than our trains will ever use, but that really doesn`t matter. Hobbyking have a new kind of LiPo designed for multi-rotors that have higher mHa for longer run times, but smaller max discharge rate. These would be a good bet for trains.
I would not use LiPos if they couldn`t be easily removed for recharging. I`ve used a trailing wagon just to try the Tam Valley system. I expect I will fit receivers directly into locos in the future so will use a different type of battery technology.
As I said I had these batteries to hand which is why I used them, however ANY battery technology can be used.
The Tam Valley board being the smaller part?
[/quote]
This is the Tam Valley Hi Power receiver. Only two pairs of connections, battery power in and DCC out. The DCC out goes directly into the decoder.
So is this Controlling a Sound Chip in the Locomotive and do all the Sound Functions work OK?
[/quote]
Yes.
Is it all legal in UK?
[/quote]
Yes.
Presumably you did not get a Tam Valley Cab?
Apart from the obvious benefits that you mention I wonder why?
[/quote]
They don`t make one.
They make this transmitter: Only one pair of connections the track output of your DCC system.
You continue to use the existing hand controllers from your existing DCC system.
You could put a receiver and battery into a Harzkamel, disconnecting the track power pickups. Then you would use your existing Navigator in exactly the same way you always have to run your engine.
Where it is not desirable to use an existing DCC system, maybe when visiting other tracks, the Stanton CAB, or converted NCE PowerCab could be used.
Finally where did you order it from and the cost please?
[/quote]
The receivers are available directly from Tam Valley for $120.00. As Mark says he is going to stock them.
