gregh
I wonder if anyone can help me with ideas, or links to circuits.
A friend has just installed a long single line section where it is difficult to see the whole line. He asked if I could figure some electronic circuit to add 'signals' at either end to show if there is a train in the section. They don't have to be 'real signals' with absolute fail safe operation – just a visual aid.
All trains are battery powered, the rails cannot be guaranteed to be electrically continuous so the simple block relay idea is out. We don't want to modify locos in any way.
I use infra-red train detectors on my layout so I can use these, but trying to determine the direction of travel is a bit more difficult.
Dave Bodnar's site is my 'bible' for circuit ideas. http://www.trainelectronics.com/
But I cannot find any ideas for direction detection.
His idea of using lasers along the track, rather than across, looks promising http://trainelectronics.com/Laser_Train_Detection/index.htm
But not easy in my instance as there are curves.
I'm wondering if two infra-red detectors placed close together – less than the shortest loco apart – could be used. The order in which is detects a loco could be determined. There would be a pair at each end of the single line.
Can anyone help with any ideas?
And of course there is the added problem of the impossibility of getting wiring between the two ends of the single line due to concrete path in the way. So I'll be experimenting with radio too.
