I recently acquired an old Bachmann battery powered 4-6-0, fixed the power switch and it works !
So what to do with it, I've got several 4-6-0's already?
Decided to cut it down and make a 2-6-0 out of it, was thinking of doing a 'modern' 4-4-0 but the wheels are probably too small for that. leave that idea for another day.
Here's where I am at the moment, all cuts made and trial fitting in progress, chassis stuck together, cab end fitted and boiler shortened to match the new cylinder position. Just final filling to get a good fit and let it sit down the last few millimetres and then that can be glued up. Front deck's got a bit of a droop but once the screw goes up through the cyliders into the smokebox I think it will come right.
Get the loco fitted together and then shorten the tender a bit before putting all the details back on and painting - should keep me amused for a week or so !
