Anybody know where you can get round cap windows from ?
Thanks not sure weather to modify the existing cab or make a new one yet, Think I am going to bash the older 2020 version as it has some tatty bits to it and a couple of repairs to the front pipe work, so that cab has the raised LGB logo and number on it rather than transfers / printed like the newer version and the LGB and number has to go
It might be easier to make a cab from scratch with round windows the back two are a bit low to add what I want on the back of the cab. Found the swiftsixteen Spectacle-Window-Set but they are 28mm dia overall so too big. Then started to think what else uses round windows and had a look at model boat portholes at 16mm dia they are just a brass flange on the back of a brass tube so would probably look correct (never seen a real steam engine cab inside closeup ) and they come glazed or UN-glased. time to buy some card and do a mock-up of a replacement cab I think. I have drawn it in 3d today so have an idea of the changes that's needed now.
Send for Mr Lump Hammer......
That would work but it might chip the paint![]()
The 20212 I bought is in too good a condition to Bash so decided to bash the 2020 version, after looking on the nett at conversions, there seems to be two ways most have done it have a longer tank that follows the original height of what exists looks like the easiest way to do it as below, mock-up made out of foam board.
The harder way have a full depth tank the same depth as the cab, more work... again mock-up out of foam board.
The Images I have found where a coal basket has been added to the back of the cab they have cut the red chassis to add extra length so the bottom sits on the chassis, adding it adds around 10mm to the chassis and 20mm to the overall length of the engine but another 20mm overhang on the back end looks like it should be a 0-6-0 not a 0-4-0 so not sure about adding that bit now.
Next need to decided which looks better short tank or taller tank ?
