nico said:I have two AMS coaches with one coupler mount broken of each and i am in need of your advice on how to repair them![]()
heres a few pics of one of the coaches damage,they both have the same damage .the first pic is what it should look like
don9GLC2 said:nico said:I have two AMS coaches with one coupler mount broken of each and i am in need of your advice on how to repair them![]()
The pix are a great help in understanding the problem.
Since you have two damaged coaches, this may be a situation that is likely to occur again. A common design principle is to have a deliberate easily / cheaply replaced weak link to prevent damage to other components. Rather than reinforcing the coupler mountings it may be better to have something like a magnetic mount that will come loose if there is excessive load on the coupler. Of course this all depends on what loads the couplers are likely to see in service, both in tension and compression and the cause of the initial damage.
I claim top marks for an **** solution! 100% factually accurate, but no practical help whatsoever!
Depending on your prejudices, replace **** with accountant / IT / engineering / management / whatever!
johnsaintjim said:What's the other side of the broken boss nico? I would look to screw through from the other side into the broken portion of you can. Even if it's the platform on the end of the coach, you may find a countersunk head self tapper would do. Better, if you have a tap, you could use a proper bolt into the broken-off section.
nico said:johnsaintjim said:What's the other side of the broken boss nico? I would look to screw through from the other side into the broken portion of you can. Even if it's the platform on the end of the coach, you may find a countersunk head self tapper would do. Better, if you have a tap, you could use a proper bolt into the broken-off section.
here is the other side
don9GLC2 said:Assuming you're not going to let the courier play with your coaches!
Any coupler drawbar load acts through a lever on the boss where it attaches to the underside of the coach. This will put considerable load on the boss, just where it has already broken. While drilling and pinning or even screwing will retain the coupler in place without load you still have the problem of 'drawbar load' on the boss. I would be tempted to consider reinforcing the boss by cutting a block (wood, plastic or some other convenient material) to fit snugly between the vertical sections on either side, with a (tight) clearance hole for the boss. With liberal amounts of adhesive and perhaps also the pin / screw reinforcement.
You could also consider removing the boss flush with the underside and fitting the coupler direct to a new shaped block, glued in place.
My experience with repaired plastic bosses is poor, hence the suggestion for an additional block.
nico said:like this?
what type of glue would be strong enough,itake it super glue wouldnt work
Maybe a two part epoxy, preferably one that is thick in consistency, then it will fill any slight gaps ? :thinking:nico said:like this?
Rhinochugger said:Maybe a two part epoxy, preferably one that is thick in consistency, then it will fill any slight gaps ? :thinking:nico said:like this?
Probably a quick acting one
nico said:just a taught ,what about filling the area with epoxy glue ,and drill holes on the sides to let the glue seep through then screw into it when it hardens ?
I thought that's what we're trying to avoidnico said:Rhinochugger said:Maybe a two part epoxy, preferably one that is thick in consistency, then it will fill any slight gaps ? :thinking:nico said:like this?
SNAP![]()
