Dieseldonkey
Looking for advice from anyone in the know about using resistors with LED?s
I have a Newqida Harz 2-6-2. I?ve taken out and thrown away the 27MHz R/C kit and replaced it with 2.4Ghz equipment. Power is supplied by a 7.2v battery pack. The loco comes with 3 LED?s at each end that I now need to wire up.
I?ve tested one LED and found that it will light up satisfactorily with two 1.2v AAA batteries in series. So I?m guessing the the LED?s are rated at 2.4 to 3 volts each. I?ve read that you should not wire LED?s direct to a power supply without a resistor as this is required to limit the current. However if I wire three LED?s in series then the voltage drop should be 2.4v across each LED. This would total the 7.2v from the battery pack making me think I don?t require a resistor in the circuit. I believe a filament bulb will only pull the current it requires. Do LED?s work differently and burn out if the current is not regulated? Also if wired in series, if an LED fails, will the circuit be broken and prevent the other two LED?s working, in the same way filament christmas tree lights fail. Would wiring them up in parallel with a higher value resistor be better?
Any knowledge / advice would be gratefully received.
Thanks
Thanks
