idlemarvel
Neither idle nor a marvel
I have purchased said model and am pleased with it except for the lighting.
The front / rear white lights are very dim, and there is no option for red rear light or cab lighting.
I would like to fix these shortcomings.
My experience with g-scale is limited but I have fitted firebox light to PIKO BR80 and lighting connector for carriage interior lights and rear running lamp, so I have some idea what I am doing.
The V100 comes with sound decoder fitted; it is not quite clear which one as the manufacturer id is 131 (Trix) but I can't find any documentation about it. The LBG manual only has a few pages on decoder settings, mainly on how to adjust the sound, but no reference to the physical decoder.
It is a 27 pin decoder and the pins seem to be organised like the Massoth XLS M1.
It is mounted on a mother board and I have traced where for example outputs A1 and A2 are located on the mother board so I could use those solder pads for connecting rear running light and cab light if only I knew how to turn A1 and A2 on/off! (For the running light I could just piggy back off the main lights but I would like the running light to be independently switched.)
Q1: Does anyone know how to enable A1 and A2 and how to map them to functions like F15 and F16?
The fitted lights are quite dim because there three lights each end illuminated by a 2.5v LED and transparent plastic arrangement (light tube) to carry the light from that to the three external lights. A bit cheap and cheerful. As far as I can tell the lights are set to full power (CV 113 front and CV 116 rear both set to 255).
Q2: Does anyone know how to make these lights brighter?
Thanks for any advice.
