Since no known entity makes ready made turnouts for 32" diameter curved track I am loking to bash a single point turnout to my pizza layout.
Now every diagram and pic I see shows the movable point on the inner diameter rail with just a gap on the divergent point on the outer diameter rail, why is this?
This seams to me counter-intuitive to me. Given my uber-tight circle of track I want to build the switch with the point on the outside rail. If the movable point were on the outer rail, where the outer wheels flange would logically press more against the rail seams to be the better location for the point. IOWs if the points were straight, in the divergent position a train approaching the switch the outer wheel would come to the closed gap at the point blade and be diverted, or if it was open, the pressure of the flanges coming around the curve towards the point would automaticly be captured by the open gap at the point and the inner wheels would just follow rolling over the frog gap in either case. To place the movable point to the inner rail seams to invite more trouble, not so much in the closed straight position, but namely that in the divergent position it would be the inside edge of the inner wheels flange striking the face of the open point blade that would force the wheels onto the divergent track and would also risk the outer wheels getting wedged in the open gap of the frog of the outer rail, or at least clunking across it in loud protest.
Why were single points built that way? What am I missing?
