So, I had this junky worn out Big hauler drive. The center axle was split, the plating gone from the wheels... but the gears were good and the motor ran...
I was going to build an 0-6-0, but then I turned that locomotive into a consolidation.... so back to the junk box.. or not?
Not.... I eliminated the dodgy wheelset, cut down the c-16 frame I had the drive mounted it in, and made it into a short 4 coupled brick... dug out the one odd B'mann archbar truck I had and...
Since I run r-2s outside and r-1s in, a Forney was really out of the question, so it would have to be a single Farlie. Unfortunately, the Big Hauler wheels are too modern for a Mason (they stopped building locomotives in 1890), and I didn't have a proper cab either... What I had was one extra c-16 cab, so I moved the back wall on to "make do", and used an Aristo bobber caboose frame for the floor. I also shortened the wheelbase more than would be typical for a Mason, so it would look OK with my Kalamazoo cars. The end result is only summat a quasi-Mason mongrel. -- which I WAS going to paint it with my basic AV colors, but then my daughter said, "make it pretty"... so it's now an 1870's Mason scheme adapted to work with the stuff I had.
I don't usually bother with smoke, but I had a USA unit here... it was a real cozy fit getting it in that smokebox! And the circuit board had to be mounted at an angle in the front boiler course to clear the motor
later tonight I'll fit the siderods, but then I need to scrounge some weights before I can do anything with the boiler firebox section
