Hi Paul - here are as many mods as I can remember:
- Running plates frabicated from sheet brass and angle with the cylinder covers soldered on. They are held with one 8 BA bolt at the front and one self tapper under the cab. They are drilled to clear various holes under there.
- Lubticator enlarged to increase capacity. It used to empty in about 15 mins.
- Smoke-box door fabricated.
- Front buffer (pilot) beam fabricated from brass. Cow-catcher is an old Roundhouse white metal casting.
- Dome turned to fit over the filler valve with an off centre hole. This allows the valve to be used without removing the dome.
- This loco did run with an exhaust regulator which tamed it a bit. This was removed when the Summerlands Chuffer was installed.
- Cheap Chinese 2.4 ghz set
- PPS Cylinders are a more-or-less straight replacement - but I did it two years ago and seem to remember I had to use the original pivots so there was a bit of sorting involved. The main thing is that the holes line up and they work!
- I drilled some more air holes in the burner to stop the whistling, before I realised that I just had to turn it down!
- I re-painted it with acrylic auto paint from an aerosol. This is where I discovered it is not suitable for boilers as it melts!
- Handrails use Roundhouse parts and the lamp is fabricated from scrap bits.
I have attached a photo
Cheers
Chris
