Hi,
When I joined MyLargeScale , about 8 years ago now, it was with the intention of building a Mason Bogie ? that was done with the assistance from a lot of members: especially David Fletcher who ran a long running Master Class on building them. My DSP #12 Como was the result, and I believe that David used all the knowledge he had so carefully put together with Accucraft in China, where it resulted in the (totally sold out) Mason Bogies that they are making.
Amongst the huge amount of drawings that he has made there are a small set, for the larger versions, of which the Denver & South Park bought 4 ? these are the rarely photographed, 2 8 6 version, of which I believe there are only two photos.
In conjunction with the 2 6 6 Masterclass there is enough to make one I believe, providing that you can source a motor and gearbox unit, that can act like Barry's original version that was also the pivot for the chassis.. Therefore having found a custom builder of that, and with some expansion of some of the drawings re the chassis for which David did 4 drawings of a ?DIY chassis? for the 2 6 6 version, in styrene I have started to build one. The drawings have as far as I am aware not been used at all, which is rather a waste, so now they will be! My thanks are due to David for making the extra drawings otherwise I could not be even thinking/attempting to build one of them. THANKS David!
The full size locomotive can be seen at http://www.ironhorse129.com/Prototype/MasonBogie/dspp_286t.htm which are the only known photos of them
The boiler is quite large being the same diameter as the 2 8 0 locomotives built for the DSP by Baldwin (and the subject of the latest Accucraft model) at 60mm diameter. That was difficult to find so I made a two layer boiler to be 59mm diameter from some large waste water pipe (and I now know a source for such pipe!) and added some 1/2mm styrene to bring it up to 60mm. I have also made the slightly less fancy (than the 2 6 6 version) bell rig that Mason employed, and from 2002 dug out the Hartland domes that I had ordered back then (2 sand, 1 steam). Those were modified and added to as David?s drawings. Then it was out the plasticard for the boiler front, headlight brackets (for the Hartland headlamp) much fiddling about with small pieces were involved here!
I have ordered from the USA (Doug Bronson) a tender truck and a pilot as well, which he will kindly make on his laser cutter soon, and Barry (of Barry?s Big Trains) will sell me two pieces of his custom aluminum extrusion. Barry also returned the custom (designed by Jim Barron) driving wheels, complete with axles etc to me, for which I am very grateful, as they are a special design ? Thank you Barry!
Here are the first photos of my first steps building the loco, a trip to the model shop, emptied part of my cash reserves for ABS Plastruct so that is all now in stock; plasticard is easy, the other item is the cab: I ordered two (ages ago, one is on Como!), but the can still be bought from Doug Bronson if ordered ? as a special order. The other essential item is the valve gear that as you will have guessed is also in stock, and is I believe still available from Harald Grosch in Germany.
My apologies for the somewhat poor photos - the light was not good at all! Nothing is yet fixed, it has just been pushed together!
The blue disc is the start of the Nesmith stack from the single good (official) photo of the locos' It will be the last one built #28 'Denver', and p[ainted in an approxiamtion of the American 'Lake' color - which is said to be like plain choclate.
The firebox utilised some of the offcut from the boiler and was re-scaled from the 2 6 6 version - its larger in diameter, and yes I duiidn't see the rear sandome was wonky!
Back to work - there is an awful lot to do!
