Over in the topic on Farnham Common signal box ,
http://www.gscalecentral.net/tm?high=&m=78683&mpage=1#78846
Martino used that plastic ?board? with ?corrugations? sandwiched between flat faces - the sort of stuff that estate agents' signs and election signs are made of .
It?s a twin wall Polypropylene sheet called Fluteboard or Corflute in Australia (Known as Corex board in the UK ?)
You know, this stuff?
I got a great pile of it after elections 8 years ago and am still using it up. It?s a great material, which I?ve used for a few buildings.
By coincidence, I was building a ?1950s service station? at the same time. So I thought I?d post my efforts too.
It?s meant to look something like this:
It?s not going to live outside. Dimensions around 300mm wide by 350 deep and 250 high to the peak.
Here?s the bits all cut out from the front and the back showing the reinforcing wood I use.
I use contact adhesive to glue the wood to the board and nails where they won?t show. It?s so easy to work with ? cutting out windows and doors is a breeze.
The internal corrugations show through a bit and automatically give the effect of weatherboard for the walls (horizontal). The window frames are styrene.
And, it ?almost? looks like corrugated iron when used on the roof (?vertically?) too.
Here?s all the bits taped together to get a feel for its look and size.
If there?s one drawback, it?s that a fair bit of internal bracing is needed. This pic shows the ?warts and all? insides.
The awning roof is ?real? corrugated iron, made from plastic sheet and a corrugator tool, glued on to the board.
to be continued.........................
