How do I adjust the volume on the 4135-14-2 sound board?
I have one of these Van Based Sound Units, I can see nothing that would enable Bells or Whistles to be enacted. Quite likely the Sound Tender has a the facility via a Reed Switch and a Track Magnet to enable them?I have one of these Sound Box Cars, and when using in analogue I am disappointed that there is no bells and whistles as with the sound tender I have. Can the LGB 65012 Mogul/Sound Unit Function Trigger e fitted and if so how.
Reading the Manual it would appear not. But a ‘My Loco Sound Board’ will will you more functions. But at around £59 a pop you would need to consider if it is worth it. Though if you decided on any Battery Power that Van would make a good start as a Battery Van should you get a MLS.Jon, yes the tender does have reed switches, I though this doesn’t, I was wondering if more sounds could be made available.
