I've seen several posts about Bachmann's plastic gears in their large scale engines and how bad they are. My experience with my 38 ton shay has been no different. I was given several replacement trucks in good shape except the plastic gears are starting to crack. As a last ditch effort to save them I've thought about using epoxy to seal the cracks on the gears and keep them in place on the axle. I'm not sure that will work and might mess up the axle.
Before I give up and retire my shay to a place on the mantle, I wanted to ask if anyone had been successful in replacing the gears with metal ones from a place like NWSL. If so, which ones did you use and what did you use as a bearing puller to remove the bearing on the axle to install the gear?
