tramcar trev
My 3 channel dimmer was waiting for me when I got home today. http://www.ebay.com.au/itm/350687616075?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 Attached are the most lucid set of instructions....
There are 2 leds, red labled power, green labled "incept" viz;
in·cept (
n-s
pt
tr.v. in·cept·ed, in·cept·ing, in·cepts To take in; ingest.
[Latin incipere, incept-, to begin, take up; see inception.]
in·cep
tor n.
So one can immediately deduce that would mean you start by waiting to see the green led flash....
Seriously I have not put power into this thing yet and when I get a chance I'll power it up and see what happens. Its in an aluminium box which I thought would act as a Faraday Shield on the Rx antenna... If I can change modes eg go from mode 1 which is speed to mode 2 which would be lights on/off and mode 3 which is forward/reverse (via a small DPDT relay) by pressing the mode button the corresponding number of times this could be a winner. If, on the other hand, one has to press it 21 times to get back to mode 1 (speed) it may be simpler to use it for some other purpose or just use it as a single channel controller. I do like the telescopic antenna on the control box....
Neil R also was going to play with his when he gets it, no doubt he will immediately make sense of the"User manual"....
in·cept (
in·cep
