Melbournesparks
Finally got around to testing and uploading a complete 3D printable tram truck. Using the same tram traction motors developed previously, you can use this truck to re power Bachmann trams, or for your own scratch building projects.
Brill 21E trucks like this were extremely common on early 4 wheel trams all over the world. This one is modelled to approximately 1:24 scale, though they came in various sizes and lengths.
It is designed to be fitted to a Bachmann tram using the existing screw holes, though note some cutting and trimming of the plastic mounting posts will be required.
You can download the files from thingiverse:
21E tram truck 1:24 scale by Melbournesparks
This is a complete Brill 21E tram truck for 45mm gauge, 1:24 scale trams It is designed so that it can be fitted to Bachmann G scale trams using the existing screw holes, though some trimming and filing of the mounting posts will be required. The mountings are designed to allow the wheelsets to...
