Well this 'radio' dummy
I took the step from track power to onboard battery power quite early on, basically using manual speed controllers.
Radio control loooks enticing, for home use, so I can run 2 trains, especially while videoing.
At present I have to set the camera going,
go round behind the scenery to where the train is set up ready
switch on, get back to the camera without appearing on scene
allow train out of shot, race off & switch engine off
filming 2 trains is quite interesting!!
Also when I visit Dartbridge on the South Devon Garden Railway at Buckfastleigh, we are extending the track
& I am concerned that the longer distances that the train is away from me, could prove problematic in case of a derailment
either mine or someone elses, as the ground is uneven for precise & rapid wheelchair control!!!
I have read several of the radio control threads.
I have ABSOLUTELY NO experience of radio control
I have to consider very carefully expenditure
So
I already have batteries switches wire etc
From my reading it would seem that 2.4 is the way to go
(especially as much of my track is behind solid scenic breaks & backdrops effecting such systems as keyfob control)
Is the T5 2.4GHz the newest & cheapest option
( I run NG so only really want speed & direction control, not inertia & whistles etc)
I see that the T5 that Brian Jones sells appears to be the same as the one planet sells & about the same price
Is there anything cheaper that would do what I want As far as I can see I would need
the transmitter & receiver (T5) [about £50]
Electronic Speed Contoller ( to go upto 24 volts, Maplins only go to 16 volts) brian Jones Mac5 about £60
any other options, without buying components & doing a self build
any comments that might save me money and /or embarrassment please
So
