Chipping LGB 2067 Track Cleaner
3,535
What voltage is your relay coil rated at?
I use 12V coil relays, with a series resistor.. This allows you to 'trim' the system to get a reliable throw of the relay.
I also use track-voltage to drive the cleaning motor. - That way you are not loading the decoder with both the traction motor and cleaning motor.
richand26mhz
25 Apr 2010
298
15
Penkridge
So i wired it up via putting the "-" from the track motor to the track power as Phil said and it worked perfectly!! also the motor does not seem to be going quite as fast/violent.
I will order the speed control that Arthur posted to control it better.
Hopefully this will help anyone else that attempts this conversion.
Thanks for all the help I have received.
i can stop bothering people now :)
Rich
5,001
Wow with all the hard work on this instalation I am glad I bought a Chipped one. This thread does show what a great helpful community we have though.
richand26mhz
25 Apr 2010
298
15
Penkridge
added a solution diagram i used to get it to work. hopefully will help anyone else attempting this conversion.
Rich
