Edited Solution
The below image is for the way i managed to get this to work via the help from the participants to the thread.
I have made an easy to read diagram for anyone going to attempt this engine with a decoder hopefully better than the Massoth wiki.
The below set up used
JMRI settings
The easiest way i found to get the lights to flash was to add each light to a decoder channel then use the following setting to get them to blink. See A3 and A4 and link them to turn on via F2 with the motor.
Set F2 to turn on in standard driving direction only.
I replaced all the bulbs with 19v so set the voltage output 26
Video of the track cleaner testing.
Hello, starting another thread. whilst waiting for my DCC to get working i have started chipping my track cleaner. I have had a look around the forum for anyone else who may have done this correctly but no luck. I am programming it using a sprog 3 using JMRI.
I have tried following the massoth guide. but the guide is not the best translation from German.
So far i have
I have purchased the relay in the massoth instructions. just waiting for delivery .
Can anyone explain what the Relay is actualy used for? or have a clearer wiring diagram?
- 1x RTE24024 Schrack Relay
- 1x 8150001 XL-Decoder
- 1x Diode
JMRI settings
So far i have
- Removed the PCB and added a Massoth XL to the loco.
- Converted the motor to 4 wire.
- Connected up all the lights.
- White to +22V
- Brown to front light
- Green to -A2
- Using JRMI i set A2 to only run in the forward direction.
