chipping a lgb crock for gorden [pics needed]
mike
Master at annoying..
4,459
Rossendale
RE: chipping a lgb crock for gorden
:timeout: i can not STRESS how imporant it is at this stage to check the motors sitting corredtly, you should be able to turn the front flanged wheels , which in turn, if the motors fitted correctly, turn the rear, flangless set......
mike
4,459
Rossendale
next, i added some temp wires, and linked them to test the motor block, before i went any futher.....
mike
4,459
Rossendale
after a satisfactury test, rebuild the entire block....
this is todays progress......
mike
4,459
Rossendale
:D repeat the hole lot for the second block, which is what i hope to be getting on with......after a brew <img border="0" alt="tongue.gif" src="http://www.gscalemad.co.uk/forum/style_emoticons/default/tongue.gif" /> <!--IBF.ATTACHMENT_23986-->
mike
4,459
Rossendale
Re: chipping a lgb crock for gorden
:banghead: right start with the main boddy, open the door
mike
4,459
Rossendale
this lets us slide out the on/offy switch, and main bord, we wants it out
mike
4,459
Rossendale
disconect everything.....
mike
4,459
Rossendale
helps to remove the heat sink
mike
4,459
Rossendale
remove all wires, be creative, unsolider, or cut very close to the jiont
mike
4,459
Rossendale
so we are left with this
mike
4,459
Rossendale
next we add motor boggies,
mike
4,459
Rossendale
refit the poivet blocks we removed before
mike
4,459
Rossendale
next we meet 2 old freinds , mr muliti meeter, and papperpen
laugh, but dam usefull
mike
4,459
Rossendale
we need to figure out what each wire really dose, not wqhat we think... its very easy to get cocky, and over confident, best to check it out, cheaper too, at the cost off a fryed chip....as we are useing the egsisting wireing harness, colours mean NOTHING , a wire can be any colour, its what we do with it that matters......
mike
4,459
Rossendale
theres a open circet check, basicly, turn the knobby thing till it s on the xk10(resitansce)setting(well on mne it is) connect the 2 probes, and touch them together, the meter should shoot across, means we have a ciurcet, and that means we can test wires out
i might use the wrong names, but i know what i mean
mike
4,459
Rossendale
probes touch, we have a ciurcet
mike
4,459
Rossendale
this is wear it pays off, gorden wants a on/offy switch installing, being a skinflint northern like what i am, im re useing the egsisting factoury fitted one, we need to figure out were to tap into the bord to re use the switch..... by placesing the probes on the switch, and around the defunkd bord, we can work out the ciurcets, basicly, play about till we get a reading on the meter
mike
4,459
Rossendale
after testing the switch in veruise poistions, i found bottom off, middle on, useing these 2 terminals, so i soilder two wires on......
mike
4,459
Rossendale
right, back to thouse small lighting bords at each end, we want to remove the lighting wires, this simply means traceing the wires from the bulbs to the bord, and removeing, it should leave u 3 still atched
white, green, brown
mike
4,459
Rossendale
remember our new red wire, the motor feed wire we added, well, its going to atach to the small lighting bord, via a redudant pin.... because we multimetered it out, and found out that the pin is linked to the multiplug, in the middle..... so we can use it
