chipping a lgb crock for gorden [pics needed]
mike
Master at annoying..
4,459
Rossendale
RE: chipping a lgb crock for gorden
back wheel set simply snaps onto block, un snap
mike
4,459
Rossendale
remove the 2 screws on the motor top plate
mike
4,459
Rossendale
1 at each end......
mike
4,459
Rossendale
hello sweethart
mike
4,459
Rossendale
not the best photo, but i took 20, (and they were really bad)it shows 3 pins, we need 4, or, 3 pins and a wire..... at the mo-ment, its track power&motor feed combined, ..track power, .. motor feed.... we need to convert the 1st pin, seperate it from being a combined motor/track feed, into just a track feed,
mike
4,459
Rossendale
persons called gorden really shouldnt look now
1st off lift the motor out,
mike
4,459
Rossendale
side step here.... if u remove the base plate, 4 screws, 2 small, iner 1s, 2 larger , out screws
mike
4,459
Rossendale
it gives us acesses to the wheel sets, and pick up plungers, (bullets) but it also alows us to see how the pins are aranged....
mike
4,459
Rossendale
as u can see, the top single pin runs across the pick up skates and bullets, it also acts as a direct motor feed....
the next pin down...., is more to the middle, this also picks up power, BUT misses the motor, and takes its power to the electrical gubbins in the loco,
underneith it, just visable, is the return motor feed pin, that comes back from the electrical gubbins... it CLEARLY dosnt touch any track feeds...
now would be a greattime to change any iffy bullets, grease , ect.
mike
4,459
Rossendale
lift out the traction wheel set......
gently ease off the old traction tryer and replasce with a new 1
mike
4,459
Rossendale
now looking down the empty motor block, we need to remove the plastic on the left off the left hand pin......
mike
4,459
Rossendale
i used my dremile while goren wasnt watching.... next, clean the motor conecting tab, we are going to soilder a wire on it, so it has to be shinny clean....
mike
4,459
Rossendale
motor block with plastic dremmiled away(next to left hand pin.)
mike
4,459
Rossendale
cut a small peasce off heat shrink, and slide it over our favoiuret left hand pin, so just the top 1/4s showing, then have a smoke, and use ur lighter to warm the heat shrink up.....
mike
4,459
Rossendale
next, tin up, a sutable long lenght off wire, trhis is ging to become our motor feed wire(pin) also, we are going to tin up, the motor tab....... tinning is when u aplly a small amount off soilder to each part, before u jion them to gether
mike
4,459
Rossendale
makes soildering easy, and a strong jiont
mike
4,459
Rossendale
next, slip a short lenght off heat shrink, over the wire, till it covers the soilder jiont, then shrink it...
mike
4,459
Rossendale
next up, brew, then, install the motor in the blockBE VERY , VERY CAREFULL TO MAKE SURE THE MOTOR SITS CORRECTLY IN THE BLOCK, failure to do so will result in a striped gear wheel.... the motor should lock into plasce, at the bottom off the motor, is a location pin, it sits in a grove/slot in the base off the motor block, if it wont sit down correctly(you can tell by rotating the wheels, they both shoudnt move, as the worm on the motor should be gripping them) you may need to remove more plastic were our new feed wire est/routs througfht the block....
:timeout:
mike
4,459
Rossendale
next, mark up the motor block top, so our new motor feed wire can come through, then, dremmile the top
mike
4,459
Rossendale
feed the motor feed wire through our new hole, and screw down the top....
:D
