mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #1 take 1 perfectly good crock.......
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #2 Re: chipping a lgb crock for gorden and turn it up side down
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #3 Re: chipping a lgb crock for gorden remove the inner 2 screws here
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #4 Re: chipping a lgb crock for gorden pull out plastic pipe here
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #5 Re: chipping a lgb crock for gorden remove 4 boddy screws at the 4 conners
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #6 Re: chipping a lgb crock for gorden remove boddy, carefully as gordens watching
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #7 Re: chipping a lgb crock for gorden get ur self a nice plastic container for the screws, and spare bits......
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #8 Re: chipping a lgb crock for gorden slide the noses off the base plates, gently.....
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #9 Re: chipping a lgb crock for gorden take photos off the wireing, ... trust me, if u dont, ull wish u had plase dont ask how i know
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #10 Re: chipping a lgb crock for gorden unscrew the electical block, remove all push fit wires.... unscrew the poivet block under it
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #11 Re: chipping a lgb crock for gorden like so
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #12 Re: chipping a lgb crock for gorden leaves us with this
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #13 Re: chipping a lgb crock for gorden remove the crank screws..... and washers under nieth
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #14 Re: chipping a lgb crock for gorden remove the front coupling hook...... :wave:
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #15 RE: chipping a lgb crock for gorden because this gives us acess to the plow, which inturn holds the motor block in......
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #16 Re: chipping a lgb crock for gorden lift it out,
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #17 RE: chipping a lgb crock for gorden remove hex nut that holds crank on to fake drive wheel....
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #18 RE: chipping a lgb crock for gorden carefully lift off crank
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #19 RE: chipping a lgb crock for gorden remove screw from back end off motor block.....
mike Master at annoying.. Staff member GSC Moderator 24 Oct 2009 51,806 4,435 Rossendale www.gscalecentral.net Best answers 0 4 Nov 2009 #20 RE: chipping a lgb crock for gorden slide out motor block, make brew, we deserve it
