Revok
Recently I had to replace the axle cogs on my LGB 'Casey' loco. After a couple of false starts I got the correct cogs and fitted them successfully. The loco ran fine for about an hour doing simple loops round the track. I left it running, and when I came back it had stopped. The PSU (a piko 1.5A controller) had tripped. So I reset the psu, and the loco started to move forward, but in a very jerky way. Then the psu tripped again. But here's the thing. It would run in reverse with no problem at all. Occasionally it would run forward, but not for long before this stutter jerky would happen. Go back to reverse and it was fine.
I put the loco onto my test bench upside down so the wheels could turn freely and attached a variable psu. Runs fine both forward and back, drawing about 0.3A at 6v, and up to about 0.5 A at 15v, which I think would be about right. Used my fingers to apply a bit more load to the motor, and the current draw increased bit not by much, certainly nowhere near enough to trip the piko controller. I couldn't see anything wrong at all.
I removed all the motion rods in case it was something to do with quartering, but still on the track I was having problems going forward, but never in reverse. There were times when it would seem ok for 30 mins or so, then stutter and psu trip. Always fine in reverse. Frustratingly I could never replicate the issue on my test bench though.
So, to cut to the chase. I had read about ball bearings on some motors at the end of the worm shaft. With nothing to lose, I thought I'd try simulating that with a shim of plasticard wedged into place. To my surprise, the loco worked fine after that. Used it all day, for long stretches pulling a couple of wagons. Same next day, so feeling quietly confident the proplem is resolved, and all I need to do is get a ball bearing.
But I don't understand why! Can someone make any sense of this?
