wandgrudd
What DDC control system is everyone using, views required?
So eating humble pie here after praising the virtues of my trusty MTS3 (+Massoth Nav) system I have hit a bit of an unexpected snag. I have hit the 32 loco limit, which is a bit of an issue when you have 30 years’ worth of locos to sort out, brought it in 2013 so it owes me nothing but having decided to speed things up and chip all my remaining locos and do away with the duel analogue / dcc control I have been using I need something with more storage, don’t think I need any more amps as I seldom go over 3.5-4 amps, to run any more just becomes a bit too labour intensive as I have an inverted figure 8 layout so I would be forever checking were each trains is.
I have looked at the main options (noted below) I think but could do with people’s opinions good or bad, or other suggestions.
Piko system, 10000+ locos, 5 amps but quality seems a bit of an issue going by the few reports I have seen on here (built to a price)?
The CS3 (MFX) limited to inside use as the base station is also the controller or have, we other options with this?
Full Massoth system again 10000+ locos, 12amps possibly the best bet as I can us my existing nav and wireless bits but seems over kill as the current limit of 5 amp I have with the MTS3 system is more than enough, (i.e. do I really need the 15(12) amp dc power supply)
Has anyone looked at the MD Mxion MZSpro I have used a couple of the DCC chips recently which have been good but haven’t actually seen anybody use any of their other stuff?
Andrew.
Andrew.
