Ralphmp
I'm pretty sure this must have been covered previously but I can't find it using the search tool.
I'm adding sound via a Massoth eMOTION S decoder to a loco which has a Massoth L decoder already installed. I will be connecting the 2 decoders using the SUSI interface. Maybe it's me, but I can't make much sense out of the Massoth manuals (eMOTION S installation manual and CV Settings manual for the S decoder) on whather I should set both decoders to the same address when using the SUSI icable or whther this is a big no-no. I think they're telling me that
In other words, to set up the S decoder before installing it - e.g. to adjust the volume level - I use CVs 1 to 236 (for volume setting this would be CV 200), but after installation when the 2 decoders are linked via the SUSI cable, if I want to adjust the volume again by POM or putting the loco on a programming track, I'd select the loco using the address of the L driving decoder and then use CV902 to set the volume on the S sound decoder (CV902 is the one that equates to CV 200 according to the manual).
If Im correct then this seems a straightforward way of doing things, but it's a big "IF" as I don't want to have to take the loco apart and reprogramme one or both decoders separately if I b*gger things up.
Can anyone confirm I've got this right, please, and if not, correct my miunderstandings?
Thanks in advance
- if I DON'T use the SUSI interface then the 2 decoders must have the same address, and to ensure I can change CVs correctly once the decoders are installed (e.g. via POM), then I need to set a valid long address using CV107 & CV108 (using same method of address calculation as for CV17 & 18); the manual mentions a default of 320
- if I DO use the SUSI interface then the address of the eMOTION S doesn't matter as the key decoder functions are accessed via CVs 900 to 979.
- Whichever method I use to connect the 2 decoders, if I connect the S decoder directly to my Massoth PC interface to programme it, I set the functions I want using CVs 1 to 236
Thanks in advance
