KeithT
From 8am to 9am all tested perfectly including the hard wired Crazy Car dodgems.
At 10am the first visitors arrived and mayhem ensured.
Neither of the two Massoth XLS encoded locos would respond correctly to the commands. Pressing 4 for a station announcement might produce a long whistle next time it could be braking sounds. I swapped from wireless to tethered then swapped the control unit for a spare but the same happened. A loco might stop then set off on its own or reverse, often with the lights flashing.
Several times on pressing a key for the loco coded 3 would produce (wrong) response from the one coded 2.
False analogue worked perfectly on my Bachmann locos.
What on earth is happening? Is it possible that someone nearby has a transmitter pushing out a very strong signal? I can't think of anything else.
I mentioned the dodgems, they worked perfectly early on but not later. Probably sheer coincidence.
On the subject of open days I am posting something in the Electric Locomotives section.
