Wanted LGB 4 pole motor block connectors
Brixham
I need 2 or 3 of these to repair a couple of ‘bodged’ conversions from the older 3 way to newer 4 way connector block.
Hard wired to the motor pins is not the way to go for a long term solution!
Malcolm
Would four wires with the correct crimps on be any good to you?
Like the ones that used to be supplied with the Massoth decoders..
I can probably find some of these..
Thanks guys, I had forgotten about the crimp connectors supplied with some massoth decoders,
Philip....will you be at Hinckley on Friday/Saturday?
Malcolm
Malcolm
I am hoping to get there one of the days..
Depends on any short-notice hospital appointments.
Malcolm
I was thinking of suggesting them but your query appeared to preclude them. I would suggest a small piece of heat shrink on the end of each a good tight fit will do rather than shrunk on.
The easiest way to get hold of a motor block connector is to buy a complete motor block to PCB connector cable from a parts supplier like MTS and just cut off the PCB connector if you don't need it. The complete cables usually cost about 7 euros.
