Zerogee
Clencher's Bogleman
Hi, this may be a very silly question, but please bear with me.....
A few weeks ago I DCC chipped my black Dingler DR Ts3, some of you may recall the threads about it that I posted on here. The only thing that went wrong is that stupidly I didn't check the lighting voltage first - I set the decoder (Massoth LS) down to 5 volts, thinking that would surely be low enough, and still managed to blow all the bulbs out....
I haven't managed to replace them yet, it's going to be a tricky job as they seem to be tiny grain-of-wheat bulbs that are hardwired in - they appear to be 3 volt, and make the LGB bulbs look robust!
Now, that little disaster aside, I now need to put a similar decoder into the new green version of the Ts3 that I've just acquired - obviously I've learned my lesson about the bulb voltages, but here is where the silly question comes in:
The loco, as supplied in analogue form, has a voltage stabiliser package on a little circuit board - this is a pic of the one that I took out of the black loco:
This seems to supply 3 volts to the lighting systems; there is no directional lighting, they are either all on or all off.
Now, when I do the install in the new green loco, would there be any problems if I hedge my bets by leaving this voltage stabiliser IN the circuit rather than removing it, and simply connect the inputs of the stabiliser to the interior light output of the LS - so that whatever voltage the LS puts through it's lighting output, the stabiliser will still drop it to the voltage required for the bulbs? I know this is theoretically redundant, as the LS lighting output could just be set down to 3 volts, but my question is would the belt-and-braces approach of leaving it in actually do any harm?
