playmofire
This may seem a question with an obvious answer, but I'd like to be sure that what I'm doing is right before I do it and possible find it's wrong!
I'm planning to put a short incline up to a bridge and then down again in a layout I'm working on. I'm using LGB 50614 track mounts, LGB 50612 single layer bridge piers and LGB 50611 bridge mounts. The bridge piers have four small "pins" on the bottom, one on each corner and these are presumably to lock into another bridge pier where one or more piers are on of top of another. However, this leaves the question of the bottom pier - presumably, the "pins" are carefully cut off so that the pier lies flush on the baseboard.
Confirmation or otherwise would be gratefully received.
