55.5 said:This must be your lucky day! I can let you have some lgb plastic wheelsets for a mere £25 per axle.
Or a hell of a lot less if you're prepared to haggle!!!!!!!!!!!!!
The exploded diagram for the LGB version shows identical axle holders with a coupling adaptor at the veranda end only. The photos appear to show an adapter at each end.korm kormsen said:look here
pugwash said:So in theory one adapter could be removed, or seeing as the couplers are held to the adapters by screws the overly long adaptor could be shortened and the coupling refitted?![]()
The reason I ask is because I like the look of the wagons but want to stick to 4-wheelers, but not if they look like they have an aversion to each other.
Looking at those pix as posted by Korm, it should be possible to remove the extension piece, so that the coupling is lined up with the buffer, not beyond it.Rhinochugger said:pugwash said:So in theory one adapter could be removed, or seeing as the couplers are held to the adapters by screws the overly long adaptor could be shortened and the coupling refitted?![]()
For the price of these wagons, there's gotta be a way of doing it![]()
garrymartin said:Hi Everyone,
I've just bought 2 as well for the same price. My intention is to remove the verandah & roof overhang , then repaint them grey in the hope they they will give the impression of G.W.R. MINKS . Well they might if I stand some distance away & squint. The writing on the trucks doors made me laugh. " Railway express , Royal Giving , Special Tunnel , Train Model of the World " not much research there then!
Cheers Garry.
P.S. it works the other way too , the 70's advertising campaign that ended in the slogan " Come alive with Pepsi " was translated into mandrin & used , It's claim was " Pepsi brings your ancestors back from the dead ! " bet that went down well in a country where ancestor worship was the main religion !
