Zerogee
Clencher's Bogleman
A question to Those Wot Know, about track entering and leaving a gradient section (simple adhesion track, no racks involved).....
I am installing a moderate (about 3.5%) gradient to connect my ground-level track to a section on raised bed areas; the gradient will be laid in ballast on top of solid blocks, as can be seen in this pic:
The unconnected 6' length of AML track illustrates where the track will run up the gradient, and at the top end of the ramp there will be an LGB girder bridge carrying the track over to the raised bed that can be seen at top right of the pic.
This pic shows the bridge end more clearly (note that bridge positioning is not final, it is just placed roughly in position here):
My question is, does anybody have any advice for managing the vertical transitions into and out of the gradient section? I want to avoid sharp vertical bends in the track at top and bottom of the slope.
At the bottom end there is probably about 18" between the point that can be seen on the very left of the first pic, and the start of the incline - what I want to avoid is any tendency for the point itself to twist due to the upward slant as the track enters the gradient, and also obviously to minimise any derailing risks - and then the same as the line levels out at the top to cross the bridge.
I am generally clamping all track joins everywhere on the line, but what I had thought was possibly having the vertical transitions made up of several short pieces of track (like 150mm half-straights?) joined only by the push-on fishplates, but with each such joint bridged by soldered wire jumpers for electrical continuity (after successfully soldering the power cables to the track last weekend, I'm no longer put off by the thought of soldering directly to the track!)....... would that allow sufficient vertical flexing of the track to avoid any potential problems?
All advice and ideas gratefully received, so over to you chaps.......
