Airbuspilot
I have fitted a new motor operating the cleaning wheels in the LGB track cleaner but still have problems. With the cleaner on the track I have normal forward / back control and the lights work normally. When I select the cleaning motor to ON I have what appears to be a short in the cleaner itself, not the track.
By short I mean - cleaner stationery, forward lights on, speed control zero. When speed control moved forward all lights fade to off (quickly) no motor reaction. Cleaner running forward and with cleaning option OFF, when ON selected cleaner stops dead and lights off.
With the cleaner on the bench and powered with crocodile clips from the main track (cleaner inverted) I have normal cleaning operation. I have started and stopped the cleaning wheels multiple times with perfect operation and no shorting.
Placing the cleaner on a rolling road with the cleaning part supported away from the track (no load) again perfect operation with multiple stop starts.
Immediately placing the track cleaner back on the main track normal operation for around 90 seconds then continuous shorts each time I try to run.
With the speed controller set to run the cleaner cycles between power on / short / power on / short. Normal static current drawn on the main track is around 3.15 amps, each time the cleaner shorts the current drops to about 2.8 amps.
My initial thought was a load problem however this is a new motor and the short occurs without a reaction from the motor so I would think unlikely?
I am now totally confused, any ideas would be gratefully received.
Robin
Robin
