CoggesRailway said:
After seeing Whatlep's set up I have been thinking abou how much more flexible running/playing digital provides however I am a bit sceptical (probably becuase I don't understand it all). Anyway a few questions...
Intial start up costs to incude 3 decoders and control of 5 points - very roughly is fine I have no idea and it's not easy figuring out when you don't kno wwhich bits you need.
Massoth or LGB? What is the difference?
Are LGB currently a going concern with full tech support and future plans for the product? Future usefulness of locos, stock and track is not really effected bu this, but a sophisticated product does need to be supported etc.
I have one digital loco, i ran it in the drizzle and pop. Is this typical- are chipped locos ulitmately less reliable?
Thanks, Ian
Hi Ian
This is a massive topic. I suggest that if you want an in depth conversation we arrange for you to come over to Ruritania again so I can show some some of the intricacies of DCC, of which LGB's system is only one version.
However, in brief:
The protocols for DCC are defined by the US National Model Railroad Association (NMRA). All the systems currently on the market meet those protocols and can be used interchageably, with some exceptions (due to design) in the case of the LGB central station. Does the latter matter, not in my opinion, but it would take several pages fo detail to explain fully.
What should you choose? Well, Massoth make kit badged for themselves, LGB and - very soon - Piko. The real debate for you is which central station and handset to use and whether to go radio control (the answer is "yes", by the way!). For loco chips, whatever takes your fancy, but I'd recommend Massoth's as cheapest and best. The same goes for point modules. How many modules you need depends on how many points need to operate independently. Each Massoth or LGB point module has four outputs. An output can operate more than one point simultaneously (e.g. for a crossover).
Now, costs. The big advantage of LGB MTS kit is that there is plenty around, so it comes up regularly on the second hand market. You can therefore get a start and upgrade later. For example, Glendale Junction recently had a second hand MTS Type 2 central station available at £90. LGB kit is fully supported by Massoth, by the way and repairs are readily available.
Piko's kit is not on the market yet, but should be before Christmas. Capabilities are not yet known, but the handset is clearly designed to be a slightly reduced specification version of Massoth's handset and the central station to have the LGB kit's output (5 amps), but with Massoth electronic standards, not LGB.
However, let's assume you're buying new today from Dragon G Scale:
Massoth 1200Z - £829.95
Massoth handset - £189.50 (without radio control)
OR
LGB MTS III - £280.95
LGB 55015 Universal Remote - £143.95 (without radio control)
If you go for radio control, the costs look like this:
Massoth handset - £250.00 (r/d fitted)
Massoth radio-control receiver - £99.95
OR
LGB 55050 handset transmitter - £75.95
LGB 55055 radio-control receiver - £135.95 (*)
(*) - Receivers can handle the signal from multiple (8) handsets. You will only need 1 per layout in normal circumstances. LGB and Massoth receivers work on different frequencies. Handsets of each supplier will only "talk" to the same supplier's receiver.
Note that these are not "like for like" comparisons, as the Massoth central station can pump out more amps and hence control more trains and the Massoth handset has more functionality, assuming you have the dexterity to use it! Also be aware that the Massoth handset can be used either cabled or radio-control with an LGB Type 3 central station, but not the Type 1 or Type 2 versions. Getting complex, isn't it!
Remember too that you can get the LGB kit much more cheaply than the "new price". Say £100 for a central station and £75 for a universal remote. The other items at perhaps two-thirds of the prices shown. We could juggle numbers and upgrade costs all afternoon - the best thing to do is come over and have a natter!
Decoders - Massoth XL at £55.95 each
Point Module - Massoth 8156001 at £54.00 each
Like I said, we could - probably will - write reams on this, BUT there's no substitute for trying the systems yourself and having a chat. Feel free to give me a call and come over again for a look!
