KeithT
The ESU Loksoundcard has arrived back from Jeremy complete with harness. It works but there are anomolies. On MTS there are no lights other than the two small ones either side of the smokebox whereas on analogue they all work as they should. I have set the switches in the smokebox correctly for each mode.
Speed control is v crude on MTS but again OK on analogue; the sound is more limited on analogue with just the chuff and some escaping steam noises. I have not tried smoke as yet.
The harness only connects to one of the two banks of sockets on the card. Can anyone advise please if this is usual with the ESU card as opposed to a QSI which uses both banks?
Also, I have experimented with two 8Ohm speakers which seems to give bigger, "wider" sound but, I wonder am I overloading the electronics if I make this permanent? That is assuming I can fit both speakers into the tender.
