trammayo
This loco was an ex-seasonal set. I gave it a little makeover to hide its' origins. Right from the start, it proved troublesome on my trailer layout. It was my first experience in G Scale of the (Bachmann) non-standard bogie swivel system. Common it was on Basset-Lowke O Gauge I know, but it was PITA on R1 reverse curves.
If it derailed, the truck would either catch under the cylinders and/or side swipe the motions slide bars. Such was the truck's wandering tendencies that it finally destroyed the side bars.
I must confess that, as I my trailer trackwork was laid flat, it may have contributed to the derailments. Eventually I added some slight super-elevation to the curves (but too late for this loco).
In the end, I purchased a chassis (well two actually) off that well maligned auction site and it/they awaited fitting. Yesterday was chassis exchange day!
Pics of the loco's predicament...
The replacement chassis was the type with the valve gear as opposed to the original (supposedly) inside gear.
It was a fairly simple fit - and the wiring was just black to black and red to... - just had to find some screws and snip off some locating lugs on the footboards above the air tanks. Once back together I tried it out...
Everything worked fine - which it should have done as I had tested the chassis on the track when I got it - the only anomaly being the colour of the wheels (the replacement being black as opposed to the dark red of the original).
So another loco returns to the fold and, I have a chassis to carve up to replace a growling Santa Fe BH - the original truck will be grafted on. That will leave me with an operable 0-6-0 chassis (ear plugs are cheap) - plus the other purchase!
