Stainz bits
sparky230
what version chassis and stack?
the long bolt version is the earier version, would guess yr stainz has raised numbers on the cab?
newer versions have printed numbers and a hollow stack that takes a smoke insert and the nut is inside the boiler
if you want a plain stack with a long bolt i have several and have some used snow plows.
fiver plus postage?
will look later if i got a headlight,do you need a lens and insert as well or just the outer
