riderdan
Hello all--first post here... a question I've already asked on MLS but realized GSC is more likely to provide an answer...
Building my garden railroad this Spring, and I'll be running pre-war German locos and rolling stock and am interested in switching out the solid plastic buffers on the Piko freight and passenger cars for sprung brass buffers, and changing out the hook and loop couplers for chain, as it's more prototypical for the location/era. Is there anyone who's made this transition who can comment on potential pitfalls or things to look out for?
I've searched here but haven't found anything about anyone running sprung buffers with chain. That could be because there's nothing posted, because the search is off, or because I'm doing it wrong
The sprung buffers I've seen don't seem to have a lot of travel, so I'm wondering what the total buffer compression on the inside pair of buffers would be. If there's not enough buffer travel, my plan was to chain up the cars just tightly enough to have the buffers near full travel on the curves--probably that means that the cars wouldn't be buffer-to-buffer on the straights except when slowing.
I've got a whole slew of questions about running sprung buffers. For instance, with the light weight of unloaded cars, I expect that there might be some accordioning when decelerating/accelerating. How do you overcome that?
Also, how much additional work is it to couple cars when the buffers tend to push the cars away from each other? Since you can't realistically chain cars together and then tighten a G scale turnbuckle, do you need three hands? One to hold each car and one to hook up the chain?
Thanks!
Thanks!
