My reverse loop is fully automatic
and the LGB R1 radius point is spring worked BUT not all my stock likes pushing the blades against the spring and some derail :thumbdown:. Before I alter anything can I ask the perceived wisdom of those of you who have already been here if spring worked points are better being set in one particular direction.
I'll clarify (I hope). My track design dictated that the trains go through the point facing taking the straight leg (Main line), go round the loop and push the points over using the curved leg (Branch line). This was my preference but can be swapped if those that know recommend only using spring points in the straight line direction 8|. If I hadn't just ballasted the loop I would have experimented but my thought process takes so long that I've usually done something to make life awkward before the light-bulb suddenly illuminates above my head
