Having run my trusty Spreewald 21741 loco today i noticed that the smoke stack was at a strange angle. On further investigation the base of the chimney showed signs of melting which had deformed it both in a forward and sideways direction.
I have now rectified the problem by protecting everything but the chimney and gently heating with a hot air gun until i was able to get it back in the correct position and with some careful cleaning up it looks almost as good as new.
Has anyone else had this problem. The smoke generator in the chimney is still working after the fix and i cannot detect any excessive heat around the chimney base after a couple of hours of running ?
