My intention is to use a Massoth "S" decoder on my current Garratt project. This decoder has a 3 watt sinus output, so I would expect transient outputs exceeding this figure. My speaker location is a problem as most suitable speakers, by dimension only, are only 2 watt output. For a 3 watt decoder, I would anticipate a speaker of around 5 watts to avoid 'overpowering' it. The Visaton 50mm round speaker (5 watt output), would be ideal, however, its 33mm height is a problem.
Now, my question. If I wired, in series (16 ohms impedence), two 8 ohm speakers, then would the total wattage output, say two by 2 watt speakers, be suitable. The higher numerical impedence would reduce volume somewhat, but I am hoping that it would also take care of the decoder wattage as well.
I was thinking of a 2 watt speaker (40mm X 40mm) in the rear tender and a similar 2 watt speaker buried inside the loco boiler. A double throw toggle switch would be needed as I would need continuity when programming the decoder/s. In one selection it would power both speakers (normal operation). In the other selection it would only power the speaker in the tender (for programming). Any thoughts?
