sound card
freelander
Hi all, may be a long shot but has anybody got the old style sound cards from Mylocosound for sale, it is the type you can change the sound effects with a screwdriver I am looking for the steam and the diesel cards
Many thanks
Many thanks
Hi You might try the mylocosound dealer in the UK he might have a couple lying around, I bought the last 3 that Peter had in stock for my grand kids locos so none here in Aus although I haven't used the steam one yet.
Alan
Alan
Hi Alan, many thanks for your reply, I have spoken to the dealer in the UK without success so thought through the site might be the way to go.
once again many thanks
freelander
freelander
Sorry you are just literally out of luck. I swopped out a Diesel one just like you want for a Newer one in my Battery Railcar. Passed it onto a mate that uses them on his 16mm Garden Line that had one Diesel sans sound. Sorry.
Many thanks
What is the issue with the new ones that you won't use them?
I am planning to buy a couple and there is a problem then maybe an alternative is worth a look at.
No problem with the unit themselves as I seen at the Warley show, but I use one transmitter to run 9 different locos and to use the new model I would have to use the new handset (Sony tv handset does the same job) to controls/adjust the sound and the running of those locos which would have been fitted with the new model. the sound and adjustments of the new model are really good and value for the money but I am not looking at having another control hand set when the old ones were easily to fit into my locos and use one transmitter for all.
Freelander,
Mate think you may have misunderstood the way these things work.
From what I have read, the TV remote is used only to set up the sound and then is not used again, its just another way of adjusting the sound.
Think manual volume control on an old TV without a remote back in the day compared to what is used today
Basically you can adjust the sound without pulling a loco apart to adjust sound.
The control transmitter/receiver combo in the loco would still do the same thing, it does not change the sound card, all it does is feed speed info to the sound card.
I have the old screwdriver units installed in locos already and unless I have read the instructions on the site wrong, then its just a case of setup with TV remote instead of using screwdrivers then run trains as per the old way with no more mucking about pulling locos apart then adjusting with screwdrivers etc.
I am running a number of locos with different control systems (I run 3 different types of loco control) and believe me I would not even consider these sound cards if I had to change my locos.
Maybe the maker can confirm my interpretation.
You are correct..
You *can* use the TV remote (for volume, and the like) if you need to, but can trigger other things from your control system of choice. - Dependant on your control systems capabilities, of course.
Freelander,
from the info and demo I witnessed at the NEC the remote was used to set up the card AND run the loco my question to the person demonstrating the card was "could I RUN the loco without the remote" he stated that the remote had to be used to run and control the loco, yes you are right the advantage of the new card is that you do not have to take the loco apart to make any changes, were as the old card you would have too, if the old card was set up as I have, the only part I have to remove to make any changes is the roof or boiler off any given loco.
would be nice to see if the maker can confirm
I think wires are getting crossed here. The Mylocosound card is a sound card only. It is not a driving controller. There must have been something additional in the loco you saw at the NEC
?Possibly a Revolution?
You can get a basic sound from some of these.. But use the Revolution handset to control them.
Alan is entirely correct. I have put the New Diesel Sound Card in my Railcar that is fitted with a Revolution (this was where the Old Card MyLoco etc that I got rid of). It has an early Revolution before the Sound Ones appeared.
THREAD DRIFT ON
These days you can only get Sound Revolution Setups, a shame as you waste the Sound in them to fit a MyLocoSound Card.
THREAD DRIFT OFF.
Might be worth you looking at Peter Spoerers site, recently Linked by Alan.
Sorry to be late responding to this. I only just logged on.
MyLocoSound are only soundcards. They do not control the motion of the loco. The only devices I know of which do sounds and loco control are Revolution and BlueRail. Both only do US sounds. The former is expensive and not currently available. The latter can be used only for very small G Scale locos.
What has caused the confusion is that Freelander would have seen our small scale soundcards at Warley. These do indeed control the loco motion as well as the sounds. We did not demonstrate our large scale soundcards at Warley.
MyLocoSound soundcards are designed to work in all large scale locos except DCC. Therefore they work with all known radio control systems and with unmodified track powered locos like LGB, Bachmann, etc. In radio controlled locos, the transmitter function buttons are normally used to control sounds like the whistle, horn, bell, brake pump, guard's whistle, etc. With track power, magnets under the track can be used to trigger sounds and we also provide some automatic facilities.
Comparing our original and current soundcards, we now have a much larger selection of better quality sounds, many of them recorded. The big difference is in the way that sounds are adjusted. In the original soundcard, you had to use a screwdriver so that meant opening up the loco each time you wanted to change the volume, the whistle tone, etc. Now we use a simple TV style remote control which does not need to "see" the soundcard. You just point the remote control at the loco and press the buttons to adjust the sounds....just like your TV. No need to open up the loco. Therefore GAP is spot on.
The remote control can also be used to trigger sounds but, being an IR device, the range outside is limited.
Finally, I might just mention that the price of our large scale soundcards is still £49 but possibly not for much longer. If the pound continues its downward path we may be forced into an increase in the new year.
Regards
Peter Lucas
MyLocoSound
THREAD DRIFT ON
THREAD DRIFT OFF.
By Revolution do you mean Aristocraft/Crest revolution Train Engineer?
My understanding is that they are not being made anymore as Crest has gone out of business with limited support being offered.
https://www.rcsofne.com/crest-electronics-maker-of-the-train-engineerrevolution-to-close-business/
man
many thanks Peter for your explanation, I know what I saw at the NEC and the demo you gave, What I missed was the loco was set up using the small sound card and took it would be the same as the large card for O and G scale.
freelander.
Absolutely Gap, however they are still availabke in diminishing numbers from sundry suppliers. However it is possibke that there may be a solution and this was I think reported on here recently in the Aristo Closing Thread I think.
Absolutely Gap, however they are still available in diminishing numbers from sundry suppliers. However it is possible that there may be a solution and this was I think reported on here recently in the Aristo Closing Thread I think.
Just looked at Large Scale Central in the US a question was asked about REVO and the first reply was "REVO should be back in stock in January."
The thread then continues for about 4 pages with some colourful discussion (talk about thread drift) but in the end still no definitive answer, though the last post states "Robbie said he will have stock the first of the year and some new things. Tom" so maybe there is a solution. Standby to standby.
http://www.largescalecentral.com/forums/topic/26222/any-updates-on-revo?page=1
THREAD DRIFT CONTINUATION
Interesting thread above (in part). Have to say that I have desired Air Wire for a while now, problem is as I see it that it is not UK Legal so far as I undestand. So just hoping for Revo to come back with perhaps some UK/European Sound Projects. That may be even more wishful thinking!
Though my desire for all Battery is still present, I just would like to use the investment that I have in DCC Locomotives Sound Chips unwasted.
THREAD DRIFT OFF
