I have modified numerous troublesome trucks to give variety to the 'Island of Sodor' rolling stock, with tarpaulin tent loads and a representation of a salt truck. These are a few recent modifications. On the flatcar the entrie body was cutoff at the lowest timber scribe line. A container load is shown as an example, but farm equipment, etc, could be substituted. The flatcar has not as yet had its paintwork touched up.
Second is a simple rock load for a standard truck. The truck body was lined with three layers of cling wrap kitchen film and a baseplate of foam, cut from a LGB starter set box, was cut to size and inserted inside the truck. A layer of kitty litter (preferably unused) was built up inside and then a mixture of pva white glue, a few drops of kitchen detergent and a small amount of water was poured over the load. The mix was repeatedly applied over a period of several days. The load was then carefully removed and allowed to dry thoroughly. Plaster was then applied to the sides as a cosmetic improvement (not seen once load inserted). After sanding the plaster to suit the size of the truck body, the load received several coats of pva white glue to harden the surface.
